Raising the jib tack higher on forestay
y knot
Jun 5, 2004
15
Oday 272 Sarasota Bay
Does raising the jib tack have a negative affect on sailing speed? I did it, so I could see better under the jib.
Nov 8, 2010
11,386
On an Oday 272 don't worry about it. Any small performance hit will be basically unmeasurable.
Just make sure that you can still get correct sheeting angles from your genoa car. Moving the jib up DEFINITELY effects that.
Joe
Jun 1, 2004
8,346
Actually, it's pretty easy to make your own conclusion here. You can experiment with height by using a short length of rope between tack and stem that you can adjust. Then go sailing and watch the speedo.
When you determine what length works best.... go over to West Marine and tell them you want to build a wire pendant. They have a little work area in the hardware department with tools and parts to do the job yourself.... they will probably show you how just the same. Essentially it's a wire with a thimble/eye on each end. Your choice on connectors.
