P
Paul I
One of this year’s off season projects is to raise the boom on my Hunter 31 in preparation for fitting a bimini this summer. Raising the boom will provide some much needed headroom. After looking at it last fall, it appears that there is enough play to raise the boom about 14” on the mast and still keep the mainsail luff taunt. Moving the gooseneck seems straightforward enough but I’m not sure how to reattach it to the mast. Is it best to rivet it or drill and tap holes to screw it on? Do I need to use aluminum rivets/screws to prevent galvanic corrosion on the aluminum mast? What’s the best way to refill the old rivet holes? I will also need to cut into the edge of the sail track with something in order to provide an entry point for the sail slides. My plan was to use a Dremil cutting disk to remove the edge and sand it smooth with a Dremil sanding drum . Does anyone have a better idea? If you’ve done this before, I’d really appreciate any pointers you may have.
