Raising The Boom ?
Cherubini 37c HULL#37 Alameda
We have a 79 with the traveler mounted in the cockpit just behind the companionway. The boom is mounted really low. We want to add a dodger and bimini setup in the near future so the boom needs to be raised up at least a foot. It would also be more comfortable to be able move around the cockpit w/o the worries of being bowled overboard in a jibe. Was wondering what all is involved including dealing with the main sail and cost associated in doing this from those of you who have done this or any advice or idea's Thanks in advance.
Aug 17, 2013
1,098
Pearson P30 202 Ottawa/Gatineau
if you raise the boom, make sure you have enough room to fully raise the main sail
Jul 7, 2004
8,502
Hunter 30T Cheney, KS
I would be surprised if you have an extra foot of travel at the top of the mast. You may have to get the mainsail cut. An upper deck mounted traveler is really nice but probably not cost effective.
Jun 21, 2007
2,118
Since I don't really recall (but memory isn't perfect) any Cherubini 37' owners on the forum over the years mentioning the need to raise the boom, maybe just to suggest that you see if the boom is hanging down -- i.e. drooping.
If your mainsail is old (or even original) I have read that a design element way back when our boats were made was for mainsails with a long leach in relation to the luff. Something about achieving a more sail cloth area. The boom as a result would hang down at an angle lower than horizontal.
If so, then having the bottom of the sail re-cut for a shorter leach length might be an easier solution than raising the entire boom by removing and re-positioning the goose neck fittings on the mast.
When I bought my 1980 Cherubini Hunter 36 in 2007, it was still fitted with the OEM mainsail. The boom drooped. And with 6.3" me standing in the cockpit, was at my upper temple height. A replacement mainsail yielded a safer 6" clearance above my head. The leach of the mainsail can be shortened even more so that the boom actually has an angle above horizontal. May not need to be much to provide the clearance you might be looking for.
Alctel
Dec 13, 2013
264
Hunter 36 Victoria
As above, I also have a 36 and the main droops a ton. I am going to get a new sail next year and it's going to be cut differently so the boom angles slightly up.
