Mike
I recently upgraded from a 16 foot sail boat to a Hunter 22, with the 16 footer, i could easily raise the mast by hand, with the hunter having a lot bigger mast, it seems inpossible to do, i did some research and constructed a mast raising system that uses a 6 foot gin pole at a 90 degree angle from the base of the mast, i have a block and tack system to assist in raising the mast, the mast goes up, but bends radically to the port side, almost a foot, not sure what to do, i slowly lowered the mast back into its crutch, didn't want to do any dammage to it or anything, what else could i do to avoid it bending like that? the winds were calm, the boat is on flat ground. i even put in little "baby stays" the same length of the gin pole to prevent the mast from going side to side on its way up, it works, but the top starts to bend about half way up, what am i do to? I had my girlfriend helping me, but i want this to work easily so i can launch in under an hour.
