Tony Wilcox
I have a 376 with a Pro Furl foil Since I had my mast down last year it has been a problem pulling the jib up the foil. I think there may be a portion of the foil sleeve that got squeezed when mast stored, The sail does drop quite easily but needs to be winched up which I know should not be that hard. Does anyone know if there is such a tool available to put up the foil in order to check if it is bent in, and one that will also return the groove to its proper dimention to enable the sail to slide up easily.Thanks Tony Wilcox
