RobI have the older Raytheon RL70RC chartplotter on my C320; it uses the C-MAP NT charting modules. It is a B&W chartplotter integrated with my radar & GPS, as well as the other wind, speed, depth instruments and autopilot. All systems were factory installed.The integration of these systems on-board is generally non-trivial. The current NMEA interface bus standards are voluntary and interpreted liberally by manufacturers. Raytheon (now Raymarine) uses their own bus standard as well. In general, it is better to purchase compatible systems from the same manufacturer. Raymarine systems have a good reputation for working well together. I have no experience with the Furuno systems.My preference is mast-mounting. It is generally mounted on the forward side about 1/3 to 1/2 way up. If you have a deck-stepped mast, you'll most likely have to un-step it to install the cabling. From a maximum radar range perspective, there isn't much difference between that type of mast mounting and pole mounting.I have had my jib snag on the radome once or twice. Generally, that occured only while tacking in very light air when my crew's timing on pulling the jib sheets was a tad off. You can install a radome guard fence if that is a problem.Pole mounting unfortunately places the cockpit & crew inside the near-field radiation pattern, and consequently exposed to higher levels of radiation for longer periods of time. Quite frankly, not enough is known or understood about the effects of low-level RF radiation on the human body (current Gov't RADHAZ standards are based on the gross near-term effects -- essentially heating of surface tissue -- rather than deeper, low-level cumulative penetration into the organs). My preference is to have the chartplotter mounted where the helmsman can use it -- on the pedestal. If you have the $$ and want the convenience, you can install a slaved display below at the Nav Station (I do have the Raymarine ST60 Multi-Display unit there to read wind, speed, depth, lat, long, temp, etc. while plotting positions during a passage. Very convenient.)The chart database modules are "extras" and aren't cheap, so look closely into whatever charting technology is used by the chartplotter manufacturers under consideration. The C-MAP NT (and the new NT+) chart database modules used by Raymarine are pretty good in my experience. You can join the C-MAP Club and get annual updates, use their "lease" program for short-term trips outside your module coverage areas, etc.This past Summer we left Plymouth, MA in pea-soup fog (about one boat-length visibility) and stayed in it all the way north until we reached the center of the Boston traffic separation area. It was GPS & radar all the way; that chartplotter was a real help in maintaining position & situation awareness. I still kept my hand-held GPS on & tracking as a backup though ...Good luck--RonD
