19' boat & RADAR
Watch out how they rate these. The wattage consumption adds up fast. X number of watts for the display + Y number of watts for the antenna + Z number of watts for the antenna motor. I've never seen one anywgere near 5 watts total. AND without all the parts working, the RADAR isn't working. Old CRT screens used 15 amps 12 volts alone. A 6 Watt antenna can use 5 amps just for the antenna motor, then if it was 100% efficient it needs another .5 amps for the signal. The displays have gotten much more efficient as they are no longer CRT but instead use LCD. This brings there power consumption down to about the same as a fish finder display. But a fish finder only pulses its sonar, a RADAR sends it's signal all the time. And has to recieve that singnal and amplify it too. Only the smallest units stand a chance of being used with out the motor running to keep the batteries charged, and then only for short periods of time. The new color Radar units integrated with a Chart plotter tied into a GPS are best if you aren't going to look at it an awful lot so that interprtation is both accurate and useful. It can be hard to tell what you are looking at, and easy to miss things that you need to see on an LCD display (gray scale). It takes time watching these to understand what you are seeing. And on a sail boat, with limited power, you won't get enough time to really know your unit. Add to that and that a sail boat heels, this changes how everything looks on the RADAR too. Don't get me wrong, RADAR is great, I have one on my power boat. BUT on a very small sailboat, there are so many other, cheaper things that are so much more useful, it just isn't at the top of the items I would add to the boat.
