Radar GS 932 mono user manual
Jan 12, 2015
38
beneteau oceanis 390 herzelia
Hi,
Does anyone have a user manual for a GS 932 mono radar?
Attached is a picture of the radar.
Thank you
Yoram
Goldstar is a Korean company that in the 80's produced a series of electronics products for sale. Products were marketed on the lower/lowest priced model. The Cerritos address was likely a US distributor office. A google search suggests the unit came from the late 80's early 90's. One forum link supplied a list of wiring connections. No manuals were discovered. Some listings of product appear on ebay.
"Goldstar Precision Introduces New Generation Of Mono Radar"
Goldstar Precision, Cerritos, Calif., recently introduced its new generation mono radar with improved navigation and safety features for small commercial boats.
The new generation of mono scan radars, models GS924 M, GS932 M, and GS948 M, has a number of outstanding features. Some of the new features incorporated into the firm's new generation mono radar models include: echo plotting track history to observe the momentary movements of other ships at a glance; all push button control; daylight pictures presented on 9-inch green monochrome CRT; built-in 2 Electronic Bearing Line (EBL) and 2 Variable Range Marker (VRM) and 3 User's Defined Guard Zone with an audible alarm available; 5-kw transmitter output power; variable anti-clutter rain/sea; picture freeze, FTC, STC, IR available; on-screen readout of all operational information; and interfacing with magnetic compass NMEA0183 to supply ship's course.
The three lightweight, compact radar models cover three ranges.
The GS924 M with dome, covers up to 24 nautical miles; the GS932 M with a 3-foot open array, covers 32 nm; and the GS948 M, with a 5-foot open array, covers 48 nm.
In related news, Goldstar introduced a new radar junction unit, RJU-001, designed to work with the new generation mono radar series.
This " J " box will distribute the various radar control and target information signals between a single scanner transceiver antenna unit and two full function display control units.
Take a class on basic radar for recreational boating. You will find the same controls on your unit that appear on most of the units made in the same time frame. The class will help you understand the language and application of the various controls to turn on the unit, get a picture, and change the range/gain/etc... If the unit will not turn on or produce a basic image then you have a big decision. Try to find a shop to restore operation or replace with a new/used unit.
Jan 12, 2015
38
Jssailem and Brian, Thanks for the prompt reply!
I googled a lot before posting here.
Still hoping an English manual will come up...
Otherwise, I'll take French classes back to back to the "basic radar" class.... :)
Jun 6, 2006
6,990
use google translate!!!!! on the French manual
Feb 17, 2006
5,274
I am not sure if the manual is indeed in French or if just the site is French. So I guess one would have to buy it to see. Silly they do not say, so I guess one must assume it is in French.
Jan 12, 2015
38
Thanks for the advice. HS is tempting but I"ll skip it....
buying the manual and I'll post here once it arrives.
thx
Jul 6, 2017
1
gibsea 522 portsmouth
hello
i got a goldstar 924 mono manual an diagramatic
what i havnt got and can not find is the plugs for power the 14. pin plug to link the screen to the radar scanner!
