I was tired of sleeping with my rolled up dinghy in the aft berth and wanted to install radar on our boat and didn't want to go up the mast.... So, this is what we did...
A friend had purchased a radar arch for his thrawler but didn't install it yet. We brought it out to the boat to check measurements and to make sure it would fit okay. After we were satisfied with the outcome we went ahead and ordered it. We knew we had to make some cosmetic changes to fit the arch legs where we needed them. We had to remove the fuel filler neck and fiberglass it in thus relocating the neck. We made some fiberglass angled shims for the feet to fit the contour of the boat. Once we completed making the shims we were able to mount the legs and the upper arch supports. (Before we attached all the pieces together we ran the wires for the radar and some extra wires if needed later)
The kit comes complete with everything you need to assemble it except the mounting bolts. Those varied as the thickness of the deck played a part of the length. The only thing we purchased extra were the light brackets. We used those for the dinghy pulleys. We also had to get a piece of aluminum to mount the radar on.
The arch stands about 64" tall and the radar extension is another 10" overall around 74" total. The weight of the arch is 62 pounds (made from 2" schd 40 anodized polished aluminum tube) and the dinghy and 3.5 hp merc weigh less then 100 pds. total added weight is 162 pds. I forgot the weight of the radar and the support weigh an additional 23 pds.
The company we purchased the arch from is using our picture as there cover photo on there facebook page...(We got a t-shirt out of it!)
