Hi all,
this probably sounds silly to some but...
i want to upgrade my racer water separating filter and was just wondering if there is any reason i can not place it physically higher than the fuel pump?
i don't know if there is any gravity flow issues to consider or not.
thanks for any advice.
J&R
KEN is right in that it shouldnt really matter.... but there are things that can be done to make the system more efficient and easier to bleed when the conditions surrounding the bleeding process could make it a very difficult process.
A primary filter should be mounted before the lift pump and lower if reasonably possible. This allows for the air to naturally pass to the pump after a filter change...
The secondary filter should be mounted between the lift pump and the injection pump.. and, if it is equipped with a bleeder screw, it should be the highest point in the system so the air can be bled from it when necessary..
If there is no bleeder screw on the secondary filter base, and the bleeder screw is at the injection pump, then the secondary filter should be mounted lower than the injection pump...
a properly working lift pump will not allow fuel to back flow when the secondary filter is removed or the bleeder screw is opened, BUT there needs to be a shutoff valve between the tank and the primary filter so it can be shut off to prevent backflow when the primary filter is removed.... this will eliminate unnecessary priming time.
