K
Kevin
I replaced my original fuel filter with a Racor 120. My question is if I connected the supply and exit line correctly. On the top of the filter housing there are four places for fittings, labeled 1 to 4. There appears to be two in and two out positions. The instructions do not clearly indicate if you must use one in and the corresponding out on the outer side of the filter or can you use the in and out on the same side of the filter housing. In my installation using an in and out on the same side of the housing would be prefered. Any experience?Kevin
