I have a 2005 Hunter 33. Can anyone give any racing tips?
1. The boat has a 29hp Yanmar engine with a 3 blade prop. I want to change the propellar to a 2 blade Martec feathering prop. Has anyone done this and how did it effect performence under sail and power ?
2.Any tips on how to get the boat to point?
1. Don't try to point more than 35 deg. to apparent wind, keep up boat speed rather than pointing.
2. You must get a feathering or folding prop its worth a knot in some winds
3. Canal the factory main and go for a laminate with full battens and maximum roach.
4. Get an assymetric shute
5. Go for broke in wind speeds of 15 - 25 knots
6. Keep the hull clean (over here a diver does mine every couple of months or so for $50
7. Sailed well you should be able to beat a Bavaria or Bene 33/34 ft and easily if there is a lot of reaching in over 15 knots. If its on the nose you can only just keep up.
8. The biggest problem with the H33 is the small headsail and you can't do anything about it due the rigging B&R rigging. Basically I believe the mast is too far forward and if it had been placed a couple of feet back allowing a decent headsail then it would be a winner.
Don't get me wrong though its great boat and nothing gives more pleasure than surfing past others often much larger at 90 deg apparent doing over 8 knots in 20 knots of wind and desperately avoiding getting complety out of control when the big main takes over and the rudder is useles!
