Racing prop
F
Fred Hecker
What's the best make and size folding/self feathering prop for a Hunter 40ft sloop?
E
Ed Schenck
Like my "Flex-O-Fold" . . . .
on my H37C. It was an easy install, motors well although I don't think reverse improved very much. Did get rid of most propwalk. But was mostly interested in getting rid of the drag. It is a very heavy-duty prop. See: http://usboat.com/jensen/
Rich Stidger
Check out AutoStream
Fred, Check out the following links on this site. Email me if you have any questions. Photo Forum: http://www.c-2.com/upload/display.tpl?folder=Stidger73061534840&fno=17 Also search this site in the archives and current discussions for "AutoStream". You will find several article threads that give many different points of view and more detail on the AutoStream. Rich
Rich Stidger
Just search
Sorry that link doesn't work like it seems like it ought to. Just search this site in the photo forum catagory as well as the others for "autostream" Rich
K
Kevin
Hunter 40 prop.
Dear Fred Hecker, Thank you for the note. (Biting my tongue on the best unit! :) ) The recommended diameter of two blade unit for your Hunter 40 should be a 17” diameter 1” or 1 ¼” shaft. You will need to confirm the vessels engine info along with current shaft diameter to whom ever you request a quote from. The vessel went through a few changes in both shaft diameter and engine size. But all in all the 17” should work fine. Pitch will be determined by the Hp of the engine and its reduction gear. Hope this helps. Kevin L. Woody
