Unfortunately I cannot ask the previous owner as he is very sadly deceased.I understand this B331 was built in France for the previous (Scottish) owner. It has come to the time when winter jobs should be carried out, one of which is that the heater should be drained to avoid frost damage, the anodes should be checked and replaced if necessary. Has anyone done this and can they offer any tips?Confession time. I understand the water heater can operate from shore power as well as engine heat (which works fine) I have never discovered how to connect/switch on the heater duuh!I thank you in advance for your pearls of wisdom.Ed
