Construction
I believe the deck is plywood cored - certainly the cockpit seats are (I had to replace the core).I installed my own electronics. When I cut the holes for the sensors in the hull near the keel I was surprised at the thickness - between 0.75 and 1.0 inch - solid fiber glass. From many reports, Hunter is real skimpy on hull thickness above the waterline. My boat is an '83 (Hull #131). About that time Hunter had a "recall" in which they reinforced the hull in the bow area to prevent "oil-canning" in a seaway. Must have been real thin on the earlier boats. Derek
