Quick electrical question, inv. to shore
Aug 17, 2013
1,075
Pearson P30 202 Ottawa/Gatineau
Hey everyone, my wife and I are wondering how and if we can plug our inverter on our main A/C system for when out of port.
We love our coffee maker and would love to find a way not to have to install extra outlets that are plugged to the inverter.
similar to house power to generator switch, but in a small package
thank you in advance
dLj
Mar 23, 2017
4,621
I'm sorry, I'm not understanding your question. Perhaps rephrase it? Is your inverter one of these small ones with like a 12v cigarette plug on one end?
dj
Mar 6, 2008
1,391
If your inverter has a built in relay, you can connect it's output into the house circuit breaker input. This will provide 110VAC to all the existing outlets. You must provide a switch to turn off the 110VAC charger. The coffe maker needs over 500 watts.
Or you can plug in a power strip to the inverter and use it that way.
Aug 17, 2013
1,075
I should have given more info, sorry about that
I have a 3000w inverter on board, it has a single standard outlet, it is mounted on the other side of the boat compared to the galley which houses the said coffee maker.
when on dock I can use shore power for the coffee maker, but we would like to be able to use it when away from dock, we don’t want to have to run power cords , so looking a way to plug the inverter to the existing breaker
Mar 6, 2008
1,391
You have plenty of watts, Fred. An inverter of that size usually has a relay that automatically disconnects the shore power and uses the house batteries to produce 110VAC. You can then connect the output of the inverter to the existing circuit breaker and use the existing electrical outlets.
If electricity is not your forte, you may consider asking for someone for help. But it is easily doable.
I would recommend running your engine while the coffee maker is on as your house batteries will deplete quickly.
Likes: Timm R Oday25
Dec 25, 2000
5,948
Hi Fred. Our Freedom 25 Xantrex (2,500 watts) charger/inverter has an AC inout/output wired directly to all AC onboard outlets. That way shore power bypasses directly to these outlets, but switches to the inverter when not. I use the Link 1000 to manually select or turn on the inverter when I want AC while away from shore power. A marine electrician can help you set it up properly, if above your pay grade, like it is with me.
I'm assuming your house bank and starter battery are separate. How many amp hours does your house bank have? Some care here, because using the inverter to make coffee using your AC coffee maker can consume quite a few amp hours. It takes a lot of 12 VDC power to run a 120 VAC appliance. I always use our gas stove to make coffee/tea, etc. Much more efficient.
But then again, I'm now on a black cold coffee kick that I really enjoy. Never much cared for hot black coffee, but cold coffee, a different story. And it does not take any electricity, other than when grinding the beans. Just like making sun tea. Let it steep for a day in my coffee press, then chill in the fridge. Ice cold coffee/tea;: Yum!
dLj
Mar 23, 2017
4,621
What inverter do you have? It's unusual for a 3Kv inverter to only have one outlet. I'm wondering if there are hard wire connections somewhere on the unit.
dj
colemj
Jul 13, 2004
754
Which inverter do you have? I've never seen one that large that did not have wiring outputs in addition to the plug output.
If it does not have AC inputs, then it will not have a transfer switch. You would need to wire separate outlet circuits to it that are powered only by the inverter. These would need a breaker.
If it has AC inputs, then likely it has a transfer switch, and you can just connect it into your existing AC circuits.
Mark
Aug 17, 2013
1,075
I do not remember which brand or model we have, next time on the boat I will look it up.
Thank you all for the great replies
Jun 14, 2010
2,391
Mark
This! If you don't have electrical knowledge, the only safe way to DIY is to plug in the shore power cord to the output of your inverter. That will send the AC output through the boat's shore power breakers and distribution wiring.
You probably need an adapter plug or cable to connect the inverter's output socket and shore power cord. The prongs are likely different.
Edit - if you post a picture of the shore power plug and inverter socket we could offer more specific advice.
1,075
Ok, so I looked at all my boat pictures, managed to find one with the inverter.
It is a Xantrex X power 3000
7,561
Alden 50 Sarasota, Florida
… the only safe way to DIY is to plug in the shore power cord to the output of your inverter. That will send the AC output through the boat's shore power breakers and distribution wiring.
PLEASE delete this recommendation. It is highly unsafe!
Using a cable with dual male connectors exposes the user to potentially lethal voltage.
Johann
Jun 3, 2004
540
Leopard 39 Pensacola
He is saying plug the shore power cord (with a 30A to 15A adapter) into the inverter outlet. Similar to how you would plug into a portable generator. Nothing about a dual male cable. But if you were going to do that just running an extension cord would probably be better.
Heres the manual
looks like it does have a hardwired option.
It does, but no automatic transfer switch. This will require Fred to install switches and develop an UNDERSTANDING of how boat electricity works, both AC and DC.
Fred, you can't do this without manual switching and you MUST learn how to do so. You CANNOT have two sources of AC present at the same time.
  • Helpful
Likes: Leeward Rail
dLj
Mar 23, 2017
4,621
THIS!!!
A +1 is insufficient....
dj
Jun 14, 2010
2,391
That is NOT what I wrote. Read it again. My suggestion was not at all unsafe. Battery —> inverter —> shore power plug from boat is no more unsafe than plugging shore power plug into a dockside power pedestal or generator (with or without adapter for plug prong configuration if needed but NOT double-male “suicide“ adapter).
colemj
Jul 13, 2004
754
He doesn't need any switches to do what he wants, and it is OK to have two sources of AC present at the same time - just not on the same outlet.
Since that inverter does not have AC input, he can install a separate outlet(s) where he wants them and wire them directly to the inverter, while the other outlets run off shore power.
Or he could do what Larry suggested, since his original post stated he didn't want to install outlets. This would give him whole-boat AC from the inverter.
Or like you suggest, he could install a manual switch that selects shore or inverter, but not both. This would also give him whole-boat AC.
Mark
Likes: heritage
Mark,
My concern is that he may not be aware of the serious issues he faces simply because of the way he posed his questions. He appears to not be aware of Boat Electricity 101.
While you are correct in your comments, here are my concerns to your points:
1) Not on the same outlet..yes. He may not know that.
2) ...and said he didn't want to add outlets.
3) If he does, he NEEDS a transfer switch to ASSURE he doesn't have two sources of AC at the same time. He can't plug into shorepower when his inverter is on this way without a transfer switch.
4) Not "could" but MUST.
I am very concerned that he might not be aware of the safety and management issues.
1) He doesn't need any switches to do what he wants, and it is OK to have two sources of AC present at the same time - just not on the same outlet.
2) Since that inverter does not have AC input, he can install a separate outlet(s) where he wants them and wire them directly to the inverter, while the other outlets run off shore power.
3) Or he could do what Larry suggested, since his original post stated he didn't want to install outlets. This would give him whole-boat AC from the inverter.
4) Or like you suggest, he could install a manual switch that selects shore or inverter, but not both. This would also give him whole-boat AC.
Mark
Aug 17, 2013
1,075
Thank you, yes I do need a transfer switch, just didn’t know what is was called, ow where do I find one?
Mar 6, 2008
1,391
By "transfer switch" it is meant a 30 AMP relay that will select the source of AC, either when you manually turn on a switch to energize the relay coil, or when you turn on the inverter it's AC will energize the relay coil and connect the boat's outlets to the inverter output. A different set of this relay contact should disconnect the AC connected to the boats charger.
Fred, if you need a wiring diagram, PM me.
