Alternator Connection
John,Did not really intend my response as a correction, just a clarification. If you have already run the two wires you can easily conform to the recommendations by taking the dedicated alternator wire off the common and placing it on either switch 1 or 2 of your master switch. Leave the starter wire on the common. Make sure the location you choose for the alternator wire (1 or 2) is the one that is direct to a battery and not the one that goes through the other sub-switch.Your system will still work pretty much the same, your master switch needs to be in both to charge all batteries (like it probably does now). If the alternator is hooked to 1 (let's call that starter) and the house sub-switch is hooked to 2, then putting the master switch on 2 does not cause the house batteries to charge (starter battery still charges). The down side to doing it this way is that your battery charger may work differently when charging than the alternator, which can be confusing.On most newer Hunters, I believe that the charger legs are run direct to the battery bank, or actually to both switch 1 and 2. If that is the case then charging occurs regardless of the switch location. That may not be true in relation to your sub-switch.In our 290 we have a set-up similar to yours. We have a starter battery on main switch 1. We have a sub switch with two group 27 AGM's and the common of this switch runs to position 2 on the master switch. We wired the three charger legs to Master switch side 1, sub switch side 1 and 2. Our batteries will charge off the charger even with the switches off.Our alternator wire (shared with the starter), goes to master common. We have to make sure that we are properly switched to charge all batteries. As you indicated, this is not troublesome, but is something you have to be aware of.On our 356 we have two group 4d agm's on each side of the master switch. The common is hooked to the charger / inverter. We segregated the starter circuit completely using a group 27 agm. We have a simple on/off battery switch for it and the ability to mechanically combine the batteries if necessary (through another on/off switch). The batteries are all combined for charging using a Pathmaker 200 amp three bank combiner.I'm not sure that our system is better than what comes stock. I say that because although it does remove the starter issue away from the house batteries, it introduced a level of complexity that was not there before. If I ever manage to run the house banks down enough to make a difference, I'll be glad I did it. Just because the system is complex, we did add the abilty to mechanically combine the batteries, even though the Pathmaker does allow that to occur with the flip of a switch. So we have redundancy even for the Pathmaker.On the 290 we isolate the starter battery mechanically, by remembering to switch it out of the circuit when the motor is not running. On the 356 it all happens automatically.Probably more information than anyone is interested is.Dan Jonas (S/V Fieje II)
