I'm strongly considering replacing three GalleyMaid heads with Raritan Elegance models, and hope to find answers to a few concerns here.
1. I believe the discharge line from each of the heads will need to run uphill before it gets to the entry point of the holding tank. Is this any problem?
2. The Raritan literature mentions specific flow rates for the fresh water flush supply. How critical is this? Do I need to pull a line loose and time the flow into a bucket, or can I assume that the 110 volt fresh water pump can push the required amount of water through the existing 3/8" ID plumbing to flush the heads?
3.The GalleyMaids use 1" exhaust hose for the discharge, and there is no detectable permeation. Is there any reason to change these?
Are there any special considerations I should know about, or is this sort of swap as straightforward as it looks to be?
