Questions re: early Catalina 30's
Patrick Gray
I am interested in buying a 1975 Catalina, # 39, with a Atomic 4. If anyone has any comments or things to look for re: this particular boat or anything in general I would appriciate it, we are going to survey in a week or so, thanks Pat Gray
Mike Turner
C-30 Survey Points
Pat -- Several points to look at on the C-30s: * Check the deck under the mast for any depression. Practical Sailor Magaizine noted up to 1/4" deflection on every used C-30 they examined. If there are no signs of cracking or delamination evident, any deflection probably isn't too critical (but see below re: compression post and mast step). The Catalina factory has a good guide to repairing deflected deck if and when the time comes. * Below deck, check the entire mast "compression sandwich" from the overhead to the bilge. Look for any signs of cracking, softness or rot; generally you won't find any from the overhead to the sole, but it pays to look. Pay particular attention to the wooden mast step at the base of the compression post at the forward end of the bilge -- make sure there's no softness/rot, which is more common due to either leaks down the mast or from the shower drain in the head (which drains into the bilge past the mast step). Again, the factory has a good guide if the mast step needs to be replaced; if it's not too far gone you can treat it with penetrating expoxy and then seal it with regular epoxy (I've done this repair and so far it's holding great). * Check the shroud chain plates, particularly the lowers -- the older style eyebolt should have been upgraded to the more secure "u" bolt configuration. Check attachments below deck in the cabin overhead for signs of stress, cracking the fiberglass, etc. * Check that the forward cabin bulkheads in the main cabin are securely tabbed to the hull, particularly to starboard -- this is known as a possible weak point in older boats. You may want to invest in the Practical Sailor report on the C-30 as it's quite useful -- be warned that PS is down a bit on all Catalinas, but this report is the most positive of theirs I've read which leads me to believe they really liked the boat. We've had our '82 C-30 for a year and just love her -- a great boat for coastal crusing and daysailing. Good luck! Mike Turner S/Y Amity Long Beach, CA
A
archie christian
early catalinas
Wow! Hull thirty something. Well, I've got #312 and I promise there is alot to look for. Look for these after market improvements. Beefed up chainplates, the originals were not real substantial and were beefed up with more surface area below decks and more. After market rudder. The original was replaced by the mfgr. Keel bolts are steel not stainless. Look for lots of corrosion/rust on these bolts to indicate excessive years of inattenton. Voids in deck core. Fuel tank servicablility Glass mat seperation on engine mount beams. These are substantial beams in the aft end of the bildge which the engine mount bolts are screwed in to. Rotting and pitting of the base of the mast post in the fwd end of the bildge. Keel fairing seperation. Where the glass and lead marry at the keel there a nortorious tendency for seperation. I could go on and on but the good news is that this is such a wonderful SV that if the price is right it is worth the labor of love to fix any of these thing since they are all very fixable. The Atomic 4 is another story. I have never had a lot of luck with mine but I love it. Go figure? Well you really get a lot of power out of that gas 30 horse engine. An older engine like mine just has problems. I'm having her overhauled finally this year. It has had a lot of abuse and still takes a lot of work and trial from me. And don't let anyone scare you away from a gas engine. Just treat it with the respect it deserves and it will give you the same safe dependable service any other engine would. Good Luck, blue skies, Your Sailing Friend arkansasarch@hotmail.com
Tom Soko
Mistress!!!!
Patrick, How did Mistress (C30#39)get to Seattle???? I used to own her from '82 to '92. Sold her to a couple from CT who were planning to take her to FL. Pretty impressive teak. I had the A4 rebuilt and she ran like a top. If you want, give me a call and we can chat. It's been a while, but I still remember lots about her. (H)860-659-3880 (W)(860)-633-2361. Glad to hear she's still around. Tom. Julandra C36#659.
