Mark
A few questions about an O’Day 20: The drain in the cockpit seems to be clogged. I am reluctant to use a snake without knowing how the drain works. I am able to get a snake to penetrate a few inches through the bottom, then seems to hit something. Can anyone supply a diagram or an explanation? Are there any valves, flaps, etc. in the drain or is it a straight-through connection? Does the drain from the sink work in the same manner?I will be mooring the boat for the first time. Will 1/2 “ diameter be sufficient for the mooring lines? Is there a formula that determines minimum length of mooring lines? Is there any special way to secure the mooring lines to the bow cleats (previous responses indicate that a mooring bit is unnecessary)?The spreader bars are made of oval aluminum tubing that slip over tabs welded to the mast and are then trough bolted. Does anyone know of a source for replacements?Thanks for the advice.
