Questions about the Hunter 170...
134
Hunter 170 Lake Sammamish WA
I just bought a used model 170 from a dealer. I wasn't able to see the mast stepped correctly because of my schedule. I guess I should have "pressed" the dealer to see the procedure from start to finish. However, I thought I understood it.
Flash forward to my first "step". The boat was setup with the shrouds attached to both the mast and the deck. I couldn't seem to pull the mast back far enough to get the end pins into the stepped slot. So I disconnected the shrouds from the deck and then stepped the mast. With nothing to support the mast, it was necessary for my wife to "balance" the mast while I reattached the shrouds. One time we almost lost it when the mast leaned to the right. We finally got the job done, but I don't want to go through that gaggle again if I can help it.
A few days later, I happened to see a guy pulling a 170 to our boat launch and he had the mast stepped in less than 5 minutes. He did it with the shrouds attached and I'm hoping to repeat his technique next time I do it.
Is this the way other owners step their mast on the 170? The manual on page 27 implies that the shrouds are connected to the deck after the mast is raised.
Also, the manual implies on the same page that there should be a "forestay" along with jig line. I'm running with a furling jig and thought that took the place of a forestay. Is this a true statement?
Any inputs on the above questions would certainly be appreciated.
