I am looking for info on description of hull layup( solid fiberglass or cored)and what material is bulkhead under mast made of (wood or fiberglass). Are oday boats subject to blisters? Thanks in advance for any info.
Apparently you haven't been on board to see the bulkheads. They are all plywood.I drilled two new holes in the forward portion of the hull for vents for the holding tank a couple of years ago and as I recall, the plugs were cored,as is the cabin top.
