L
Lawrence
My cutlass bearing is being replaced. The propshaft has to be taken out so a new bearing can be installed. My repair guy said that he does not have to remove the rudder. Seems to me he is cutting a corner in order to do this job. The prop shaft looks like it lines up directly with the rudder. He said that the shaft can we worked along the side of the rudder without a problem.I have two concearns.1. He could bend (damage) the prop shaft while taking it out.2. He could cause a crack (hairline) in the stock of the rudder only to appear as a problem down the road.Comments
