Dave K.
I recently purchased a 1985 Catalina 30. I have used reefing with a reefing hook on the mast before, but my new boat is rigged with a small padeye directly below the boom and cleats on both port and starboard of the mast. I assume the reefing procedure is to use the line passed through the reefing point at the luff of the sail, tie a bowline in the padeye and pull the sail down with the line and cleat it on the side of the mast. For the second reef, I'd need to untie the first bowline in the padeye and repeat the procedure with the second reefing line. Is this the best way to use this reefing setup? Any suggestions on a better or more efficient way to reef using the padeye and cleat setup? Also, I have a Seaward hot water heater but no manual on how to use it. The owner's manual from Catalina doesn't help. There is a small push switch on the electrical panel for the water heater. Can it be used only when the engine is running? I have the water tanks filled but how is water transferred to the water heater? Brief instructions on use would be much appreciated. Thanks to all for your assistance.
