I installed a LED anchor light yesterday and had a question regarding operation and design. After wiring it up I tried to test continuity at the base of the mast and had no reading at all. I figured I hosed up the butt splices so I ripped it apart and re-crimped the butt connectors and re-shrank new tubing. Still no continuity. Then my neighbor in the boatyard had a battery powered tool so he attached the leads to the battery and it lit right up. How come you can't test continuity (using an ohmmeter) on an LED? Is there a switch that activates when it gets the right voltage?
On a related subject Stu recommends nothing less than 14AWG wire on a boat? I could not fit 14AWG wire through the hole at the top of my mast where the wires pass through, the wire I was replacing was more like 18AWG or smaller so I installed 16 AWG tinned wire, the max size that would fit through the mast. Unfortunately the very long lead molded into the LED was extremely small diameter wire, at most 22AWG or maybe smaller. This made the butt splicing a challenge. I used 22-16 butt connectors and a ratchet crimper and was able to bet a good splice so I will assume the wire was 22 AWG. Why do these manufacturers use such extremely small wire? Also the wire was not tinned although they had tinned just the stripped section that came with the unit. It is tiny and susceptible to damage IMHO and makes connections a real PITA. Even trying to get shrink fit tubing that will shrink around both 16 AWG and this tiny wire was a chore. I had to build up the small wire with small shrink tubes then a larger size that would fit over the 16AWG and the previously shrunk smaller tubing. Is it possible they do this on purpose just to get a good laugh?
