The way VHF works is that there is what is known as the "Capture Effect". This means that a stronger signal will capture the receiver completely and prevent it from receiving anything of any weaker signals being transmitted at the same time.
This means it can never make the "Fizzsseesheriznishbizseeeshooshfizshish" sound as a result of poor antenna or connections.
You are spelling it wrong anyway!
Similarly, and assuming the squelch has not been set to zero, if the signal is too weak or there are poor antenna or bad cable connections etc, the result is normally total silence.
You said you are not transmitting correctly but in fact you appear to be transmitting okay because others report clear signals from you. What is not happening is that your receiver is in trouble and making a mess of interpreting incoming signals.
It is possible that something on board is interfering with the set's internal detection and audio amplification circuitry. Anything else running intermittently that could cause this? This mush is possibly being imported on the DC power lines. Suspect your fridge, charger, alternator regulator, static inverter, TV, TV signal amp, even some makes of LED cabin and navigation lights. Try turning on and off one at a time whilst listening to an incoming VHF message - e.g. the weather.
BTW, as the set is permanently on, little indication will be seen from measuring the input current of the VHF set. It always increases when you operate the PPT switch anyway because of the extra 25 watts put out.
If none of the above I would then suspect dodgy loudspeaker connections or poor contact or tiny amounts of corrosion where the printed circuit board plugs in inside the set's case.
Open it, look at every plug connection and wiggle them. If the problem goes away you will have a working VHF for now but won't have solved anything!
Always remember the VHF radio is your first line coms system when things go wrong.
