Bill here is a picture from your site....
...of the dinghy on the new davits. Nice install BTW! I like how you are using the lines to keep it from swinging, I hadn't thought of that, but will try it.
Now the question....Are you going to leave the outboard on the dinghy if the weather is good? I'd like to hear from you or others on how that works out. You have a rib and we have a Zodiac that has a soft bottom and a hard floor. We have 2 outboards for it. A 40 lb. 3 1/2 HP Tohatsu that we will use most of the time. I'm wondering if that is too much weight to leave on the Zodiac's transom up on the davits. I'm not worried about the davits as much as the effect on the Zodiac. Any thoughts?
The other outboard is a 7 HP Yamaha 2 stroke that we would only put on the Zodiac if we needed to go some distance in a hurry. They....
... are both mounted on the port side of the stern on the Endeavour and there is an outboard lift there, but it doesn't work that great and it sure would be nice not having to lower the Zodiac into the water and then having to lower the outboard onto it.
With the Mac we tow the dinghy and put the 3 1/2 HP on and off. It is pretty light, but I still don't like doing it and we don't want to tow with it on. On the Endeavour I think if bad weather was approaching we would take the outboard off the Zodiac also.
Thanks,
Sum
[FONT=Arial, sans-serif]Our Endeavour 37[/FONT]
[FONT=Arial, sans-serif]Our Trips to Utah, Idaho, Canada, Florida[/FONT]
[FONT=Arial, sans-serif]Our MacGregor S Pages[/FONT]
[FONT=Arial, sans-serif]Mac-Venture Links[/FONT]
Thanks,
Sum
