E
Eva McMahan
I own a 1985 Catalina 30 tall rig. The boat is out of the water and I see two parallel cracks, or gaps, in the area where the keel joins the hull, only at the front.It appears to me that perhaps the keel is cast lead or lead alloy, with threaded rods cast into the top, that run vertically upward through a spacer of approximately a uniform five inch thickness, then through the bottom of the fiberglass hull, and terminate inside the bilge with washers and nuts. It appears that the joint of the top of the spacer and hull, and the joint below, of the bottom of the spacer and the keel, were not noticeable for the first several years I had the boat. Now, however, I see, in the front only, running back about eight or ten inches, a separation between the top of the spacer and hull, and a perfectly parallel separation below, between the spacer and the lead keel.It seems to me that the joints between the lead keel and spacer, and the parallel joint above between the spacer and fiberglass hull, were assembled with a sealant compound between the materials, the nuts tightened up, then finished off with some sort of “caulking” over the outside surface, then sanded, in preparation for painting. The result was that the two parallel joints were not noticeable.Are my observations and conclusions essentially correct? And, if so, would an adequate fix be to scrape out the loose “caulking” from the surface, then “caulk” with some kind of compound, make it smooth, then paint? Or, would I be covering up some possible damage that could do bad things inside then work it’s way through again? Or, worse yet, am I wrong about what appears to be existence of a spacer, and rather there are only two parts, being the lead keel and the fiberglass hull, and what I’ve got is, one, a visible joint that simply needs sealed up and, two, not another joint above or below but rather a crack in the fiberglass hull or in the lead keel that is amazingly parallel to and similar to the joint, and which is a serious problem?Incidentally, the keel bolts in the bilge have always been kept tight. These joints I describe are presently barely visible, if not invisible, aft of the front eight to ten inches. Also, these “cracks” were not there a year ago, but became visible only very recently. IN other words, it has not been under water for many, many, months.What should I do? If I do have two joints that just need to be cleaned out, re “caulked” and then painted, with what product should I “caulk”?
