David Bradford
I have a question for the collective wisdom of the board. I'm looking at a 1979 O'Day 28, and I noticed that the hull is not perfectly fair all along it's length. About mid-ships (on the port side, but I could not see the starboard side) there is an area were the hull "dips in" a little. Actually, it could be an area that is slightly proud - maybe a bulkhead is behind it - and only makes the surrounding area appear to dip in. I would say we're talking about 1/4" out of fair over about a 1'1/2 - 2 foot area. So, does this indicate the hull is not thick enough, or at least stiff enough? Or, is this the sort of thing you see on a 20+ year old boat, and I should not infer anything one way or the other? Otherwise, the boat seems like it's in fine shape, other than a couple of spots where the deck is soft - but those are literally only 4 inches or so in diameter.
