I just completed my first eye splice in double braid (3/8"), following instructions that came with the fids. There is something I assume is wrong - there is no core in the section marked with the oval.
But, I noticed the same thing in my boat's existing mainsheet - the section of the eye splice near the "Y" has no core.
I don't understand how this would be OK... the cover is not very strong and it seems that this small section will be a significant weak spot.
What seemed to happen is that I pulled the core through about an inch below where the splice would join back on itself, then trimmed the core. As I pulled everything together to set the splice, the core got sucked up into the loop.
What did I do wrong? Should I only trim the exposed core at the very end when the splice is 'set'?
Where should the core end?
Thanks,
Andy
Thanks,
Andy
