Question #9 on sailing skills test?
Royce
I would like to get your opinion on the correct answer for the following question. Thanks, Royce You are sailing on a broad reach with 25 knots of true wind and a single reef in the main. You are preparing to round a mark and will be turning into the wind 90 degrees on the same tack. As you round the mark, your most important mainsail trim adjustment will be: Trim the main sheet Move the traveller to windward Take another reef in the main Significantly ease or release the mainsheet
Doug Rodrigues
Opening a can of worms.......
Hummmm. I see where you're coming from. The correct answer was #4, but really should be #1. Or am I wrong? Another one: On question #6, the correct answer is to load test the battery. Cranking the engine should not cause the voltage in a 12 volt system to drop below 9 volts....*that is unless the starter itself is defective. Checking the specific gravity of a known "good battery" can confirm it's level of charge. There are many variables with most questions. I guess the way to take a test is to select the first answer but without doing too much analyizing.
Royce
Question #6
was put "according to Nigel" soo I'll grant that was correct. I don't understand #9.
RonD
Had the same problem with those two
Q#9: "Trimming the main" seemed more correct to me, as it better reflected the vaguarities of the local situation. Q#6: "Reading the specific gravity" is always a correct indication of charge level, and would be my first choice as it reflects a "most likely" condition of under-charging or fluid level. However, it may not indicate a high internal battery resistance due to deterioration of the plates. A full-load test, as Calder suggests, will. Personally, I think you need to do both, as just a full-load test will not rule out the cause of an internal battery problem. --Ron
John Dawson
foam everywhere
surrounded by whitecaps as far as I can see, I'm going to haul in the sails and make a 90 degree turn? I could spill my Yuengling!
