Cog - backeddies??
He must have meant 'SOG' but the trigger-finger was too fast in attempt to be an 'expert'.Nah, I have indeed been a 'purist' willing when a naive kid, an unwilling one many times...;-)Stu, those backeddies in a river with a kayak are like an elevator, not in these dangerous channels that take you in-between rocks, shoals, then spit you out into the main current going the opposite direction, it just doesn't work like that; sounds good though.Bill, the wind is coming into the Gate to get you home 90 % of the time, but there are shoals, fog that descends quickly, freighters, fishing boats, bouys, and the fickle currents of the north and south towers that make it nearly impossible to sail at the wrong time.I ahve tacked through there, many times, and chances are you could make it or head back out to sea.A smaller engine will be okay around the bay, but there could be that time when you need the horseposer to 'claw' your way out of a hole, and I have seen those times.No one should play 'Old Man of the Sea' here and hand out information that could cause someone their life.In the clipper days, the ships would at times go out two or three times with the tide before they finally found some wind, towing the mother ship with long-boats through straits, and away from shoals.A powerful engine with a true pitch three-blade is the only way to go, and you can STILL get into trouble.
