getting ready to change my pump-out hose which goes from a fitting at the bottom of my tank straight up to deck fitting. Guess the good about this is that you get every last drop but obviously the stuff stays in hose as tank fills. My mercorator pumps from the top with a solid pvc dropping Dow to bottom..... What is one we're to use solid pvc pipe with a small piece of 101/102 or raritan to tie everything together?
As you can see all in picture it would be an easy and clean install and not subject to any flexing
