Puzzling Water Ingress Problem
Oct 19, 2019
921
Albin Vega 27 Limerick
I've posted on this previously but still finding it difficult to figure out what is going on.(I'm on a fresh water lake so the "taste test" is of no help.)I was motoring back into my marina berth two days ago after a good sail hard on the wind in a fresh breeze.As I approached the marina I applied heavy reverse power to take way off (the wind was at my back).A few seconds later as I came alongside (having turned to starboard) the 12 auto bilge pump kicked in for a few seconds, pumping a litre or two of water from bilge into cockpit (it then drains from cockpit via cockpit drains).I assumed that the heavy deceleration had pushed water forward from the aft end of the bilge (which is deeper?) to the forward end where the auto bilge pump is.But the weird part is that the carpet on the saloon sole/floor was wetted - could water have made its way *up* through the forward bilge cover - seems impossible???Or - given that the starboard saloon floor-level locker was again wetted - maybe water somehow made its way forward to the locker floor? I did have a bag of melting ice in the cool box which is on starboard side of boat, aft of sink.I can't think of any other source for the water that made its way to the saloon locker floor as the weather was hot & dry..All very mysterious and a bit worrying.Are the two events (activation of 12V auto bilge pump after deceleration & water making its way to starboard floor level saloon locker) related?I reassure myself by observing that if there is any underwater loss of hull integrity the boat would have sunk long ago?I'll try using food dye in water in cool box to see if that is the source..Suggestions very welcome.ThanksJohn V1447 Breakaway
Oct 19, 2019
921
Sad to reply to my own post but it does occur to me that the common factor in "(activation of 12V auto bilge pump after deceleration & water making its way to starboard floor level saloon locker) " is that water was moving forward - presumably due to the heavy deceleration?Food dye experiments in prospect (blue in bilge, red in cool box)... Again, comments welcome.John V1447 Breakaway
Feb 28, 2006
127
#ygrps-yiv-1106959638 .ygrps-yiv-1106959638ygrp-photo-title {
TEXT-ALIGN:center;WIDTH:75px;HEIGHT:15px;CLEAR:both;FONT-SIZE:smaller;OVERFLOW:hidden;}
#ygrps-yiv-1106959638 DIV.ygrps-yiv-1106959638ygrp-photo {
BORDER-BOTTOM:black 1px solid;BORDER-LEFT:black 1px solid;BACKGROUND-COLOR:white;WIDTH:62px;BACKGROUND-REPEAT:no-repeat;BACKGROUND-POSITION:center 50%;HEIGHT:62px;BORDER-TOP:black 1px solid;BORDER-RIGHT:black 1px solid;}
#ygrps-yiv-1106959638 DIV.ygrps-yiv-1106959638photo-title A {
TEXT-DECORATION:none;}
#ygrps-yiv-1106959638 DIV.ygrps-yiv-1106959638photo-title A:active {
#ygrps-yiv-1106959638 DIV.ygrps-yiv-1106959638photo-title A:hover {
#ygrps-yiv-1106959638 DIV.ygrps-yiv-1106959638photo-title A:visited {
#ygrps-yiv-1106959638 DIV.ygrps-yiv-1106959638attach-table DIV.ygrps-yiv-1106959638attach-row {
CLEAR:both;}
#ygrps-yiv-1106959638 DIV.ygrps-yiv-1106959638attach-table DIV.ygrps-yiv-1106959638attach-row DIV {
FLOAT:left;}
#ygrps-yiv-1106959638 P {
PADDING-BOTTOM:3px;PADDING-LEFT:0px;PADDING-RIGHT:0px;CLEAR:both;OVERFLOW:hidden;PADDING-TOP:15px;}
#ygrps-yiv-1106959638 DIV.ygrps-yiv-1106959638ygrp-file {
WIDTH:30px;}
#ygrps-yiv-1106959638 DIV.ygrps-yiv-1106959638attach-table DIV.ygrps-yiv-1106959638attach-row DIV DIV A {
#ygrps-yiv-1106959638 DIV.ygrps-yiv-1106959638attach-table DIV.ygrps-yiv-1106959638attach-row DIV DIV SPAN {
FONT-WEIGHT:normal;}
#ygrps-yiv-1106959638 DIV.ygrps-yiv-1106959638ygrp-file-title {
FONT-WEIGHT:bold;}
Have you checked the level of your fresh water tank? Could that be a
source? If it is leaking at the galley foot pump it would show up in the lower
starboard cabin locker before draining into the bilge. If the drain from the
locker is plugged it could also show up on the cabin floor.
Garry
Oct 19, 2019
921
I don't think there is a leak from water tank as I checked the outlets at aft end of tank and they are dry.I'll check the cool box drain next time I'm out.Should I be surprised that decelerating hard pushes enough water to forward end of bilge to activate the 12v auto bike pump?JohnFrom: 'McKevitt/Cluff' Garry_McKevitt@... [AlbinVega] Sent: Mon, Jun 23, 2014 03:10 PMTo: AlbinVega@yahoogroups.comSubject: Re: [AlbinVega] Re: Puzzling Water Ingress Problem
Garry
Feb 28, 2006
127
#ygrps-yiv-639147900 .ygrps-yiv-639147900ygrp-photo-title {
#ygrps-yiv-639147900 DIV.ygrps-yiv-639147900ygrp-photo {
#ygrps-yiv-639147900 DIV.ygrps-yiv-639147900photo-title A {
#ygrps-yiv-639147900 DIV.ygrps-yiv-639147900photo-title A:active {
#ygrps-yiv-639147900 DIV.ygrps-yiv-639147900photo-title A:hover {
#ygrps-yiv-639147900 DIV.ygrps-yiv-639147900photo-title A:visited {
#ygrps-yiv-639147900 DIV.ygrps-yiv-639147900attach-table DIV.ygrps-yiv-639147900attach-row {
CLEAR:both;}
#ygrps-yiv-639147900 DIV.ygrps-yiv-639147900attach-table DIV.ygrps-yiv-639147900attach-row DIV {
FLOAT:left;}
#ygrps-yiv-639147900 P {
#ygrps-yiv-639147900 DIV.ygrps-yiv-639147900ygrp-file {
WIDTH:30px;}
#ygrps-yiv-639147900 DIV.ygrps-yiv-639147900attach-table DIV.ygrps-yiv-639147900attach-row DIV DIV A {
#ygrps-yiv-639147900 DIV.ygrps-yiv-639147900attach-table DIV.ygrps-yiv-639147900attach-row DIV DIV SPAN {
#ygrps-yiv-639147900 DIV.ygrps-yiv-639147900ygrp-file-title {
FONT-WEIGHT:bold;}
In my case it was the pump itself that had the leak. Since it is the
lowest part of the fresh water system it continually seeped water whether it was
being used or not. The pump itself was damp underneath which is how I
eventually found the leak. I replaced the pump and it solved all my
problems.
Garry
