I have a new wind instrument and cable to install. I've several options, paying the yard to do it @ $75/hr (probably at least 2 hours) or do it myself. If I do it myself I will need to buy/get/borrow a bosun chair or harness and have a helper hoist me. The old wire could be used as a cable pull for the new. I don't know yet if the old wire has a connection in the mast or continues directly to the bilge. My 1990 C30 has internal halyards so there is some limited access at the base now by removing the sheaves. I did remove one and try to look up there but as I said it is very limited. (It is a great place for wasps to hangout though). I thought about adding an access a little higher up? Anyone do this?
Another thought is to have an access at the top of the compression post and add a T into the conduit for to provide connections. But the problem would still exist of getting the cable from the mast conduit to the deck conduit.
Your thoughts?
Doug
Your thoughts?
Doug
