response
Rick;There are a few suggestions. First with the old style, make sure the stabilizing lines are in place. Yep, I lost a mast once and did not like it. AS for masts, Isomat can be replaced with Charleston Spars in Charlotte, NC but you need to go through the How store for a good price. Z Spar can be replace with a US Spar as well.The mast rainign pole needs to be raised up 5-10 degrees when using the mast raise system. You need to look at the line next to the shackle to make sure the line does not chafe thru all the way. After 5 years replace the jib halyard.While raising, always stop if there is any tension to see if a line or standing rigging is caught. also make sure to shake the turnbuckles out before the mast is all the way up. Check the tightness of the chain plats particualy the shroud chain plates.When rainsing the mast by pulling on the line, if there is another party with you, tell the person to pushe the mast with a 10-15 pound thrust only. It will be alot easier to raise the mast up at the foredeck.Crazy Dave Condon
