Purposeful repurposing
Phil Herring
Alien
Mar 25, 1997
4,924
- - Bainbridge Island
Have you turned a berth into a closet, a cabinet into a refrigerator, or a bimini into a platform for solar panels?
Congratulations, you have repurposed part of your boat.
Simply put, repurposing is modifying an object or area to fulfill a function other than intended use. The possibilities are endless and unique to every boat owner.
Have you repurposed anything on your boat? Share photos here!
I can't believe you tile the walls of your head. Doesn't that add a lot of weight to one side of your boat?
My boat has been re-purposed as a tarp storage rack. :banghead: It works pretty well.
-Will (Dragonfly)
Likes: Timm R Oday25
PJL
Apr 22, 2014
55
Hunter 42 Nuevo Vallarta, Mexico
On my Hunter Passage 42 it is not so much that I have repurposed as it is making changes. A couple of the most obvious, and safety related, were: 1) lengthening the lifeline stanchions and replacing the upper wire with stainless tubing; 2) adding mast pulpits that can be climbed and have a flat place to stand at their top. In addition lots of hand holds have been added inside.
Jan 2, 2017
765
O'Day & Islander 322 & 37 Scottsdale, AZ & Owls Head, ME
My V berth has become a handy sail locker, with easy access from the forward hatch.
The board that’s supposed to be used to make an extra berth out of the U settee makes for a perfect divider: furled asymetric spinnaker on starboard; furled Code 0 (when it’s not set as it is now) on port.
Bob's your uncle.
