purchase of cutless bearing
David Sandowich
THIS IS MY FIRST TIME REPLACING THE CUTLESS BEARING OM MY 85 CAT 30.DO I NEED TO PRUCHASE IT THROUGH A CATALINA DEALER OR CAN I MATCH THE SIZE AND GO THROUGH THE BOAT U.S CATALOG? ARE THERE DIFFERENT TYPES? ANY HELP IS APPRECIATED. THANKS
P
Pete
cutlass bearing
you do not need to go thur a dealer however it would make it easier because he should give you the right part no problem! You can match size and buy it at any marine supply house also,the choice is yours!
Don Fitzpatrick
new cutlass bearing
I replaced my cutlass bearing after replacing the engine, shaft... I bought it at the local marine store, but it's also in the West Marine catalog (I'm sure in BoatUS also}. For my 1" shaft it is 1" inside diameter, 1-1/2" outside diameter and 4" length. Trellex-Morse model # Bonito. $50.00. I had one heck of a time removing the old. I hammered, used a mechanical puller and ended up using a hacksaw and cutting it lengthwise several times, being VERY careful not to mark the strut's inner tube. Any questions? (I replaced just about EVERYTHING mechanical and electrical last year on my 1979 C-30) contact me : wischbone@aol.com Good luck, Don Fitzpatrick
David Sandowich
THANKS FOR INFO
AS ALWAYS THE BOATING COMMUNITY IS GREAT... THANKS FOR THE INFO AND HELP DAVE
K
Kevin
Cutlass replacement
Dear David, Thank you for the note. You can buy your cutlass bearing through many different sources. You will need to provide the shaft diameter and the inside dimension of the strut or housing, which holds the cutlass in place. During the process I would also look over the shaft at the bearing area to confirm that there is not to much wear or scoring. Too much wear will cause accelerated wear to the new cutlass bearing. Good luck. Sincerely, Kevin L. Woody
