Pumps
Apr 29, 2012
223
Beneteau 35s5 bristol ri
Hello,
I am having trouble with all of my plumbing pimps. They just don't turn on. This includes the electric toilet pump, the macerator pump, the shower sump and water pressure. My next course of action is to see if they are getting power and then replace them all. The electric toilet pump is getting power. It was full and I emptied it out and still not pumping. The level indicator is still showing full. Any suggestions would be greatly appreciated. it's a 1983 C&C 32.
Thanks in advance!
thetone
Sep 30, 2016
377
Island Packet IP 44 Ventura, CA
Yes, first check for power. Did this happen all at once, or did they all quit over a period of time? If it happened all at once its got to be a power source problem. Were you away from the boat for a long time? If it happened one by one over time- pumps are limited life items. But you still need to check for power at each one.
  • Helpful
Likes: ggrizzard
Sep 25, 2008
7,462
Alden 50 Sarasota, Florida
Hello,
lets dissect this for clarity.
do any/all have power to them? Is there a common power feed source at or after the panel?
Why would you replace them if the only problem is no power?
For clarity, how did you empty it? Manually?
what? Are you referring here to the toilet or than tank macerator pump?
  • Helpful
Likes: JamesG161
Apr 29, 2012
223
I just bought the boat and none of the pumps worked except the toilet. I pumped out the head at a pumpout station. The lights that show the tank level are still red. I wonder if the red light stops the pump and how it can be reset.
If the other pumps are just not getting power I would fix that, if they are getting power I would test them and replace if broken.
Sep 30, 2016
377
Okay, if its an unfamiliar boat you need to break out the Volt meter and see what you've got. Just a guess, but Id say the previous owner didnt feel like replacing the pumps. Your looking at over $1k in pumps if you replace. Easy to diagnose, but probably harder on the wallet than a wiring problem. I dont think the tank light has anything to do with any of this, but I dont know how its set up.
Congrats on the New C&C 32. Is this a replacement or an additon to your fleet?
I like the idea of examining the electrical connections. Since all quit then the common ground would be a good place to start.
The value of reading Calder’s book on marine electrical systems can not be stressed enough. It is a lot less expensive than buying all new pumps. Especially if the issue is connections not pump motors.
Sep 24, 2018
3,442
Catalina 30 MKIII Chicago
If pumps are replaced and the issue isn't the pumps, then they still wont work
Likes: captcoho
dLj
Mar 23, 2017
4,427
These are notorious for not working well. I've never seen one that does anything to affect your pumps.
I wouldn't worry about this part until you've sorted out why your pumps aren't working.
dj
Likes: captcoho
capta
Jun 4, 2009
4,947
Several of the pumps you mentioned should have automatic switches in the lines. The only way ALL your pumps could be non-functional, if they have a common ground wire, which is no longer making contact. Get an auto voltage tester, not a meter. Attach one end to a convenient ground and push the probe into the positive wire. If it lights, there is power there. Repeat at each pump. If no light on any of the pumps, it isn't the pumps, but in the wiring.
Good luck.
Jun 25, 2019
32
Hunter 28 Treasure Island Marina, Kingst
As for checking power to ALL kind of accessories. the voltmeter is not enough. That is you can read 12volts at the wires, but the wires may not be able to transport the amperage necessary to bring life to whatever is connected to them, because it might have to much resistance in the wires!
When I was checking circuits on cars in my previous life, I would connect a halogen light to the wires I was checking and see if it was lighting up bright and strong. If not I would search for the elusive over resistance in the wires between the power supply and the accessory itself. Great and easy way to diagnose faulty wires and/or connections as long as you do not overload the wires with a too big light!
7,462
That seems like a complicated way to verify continuity (zero resistance) but whatever works.
Sep 30, 2016
377
Maybe, but it does have merit, as I found out a few weeks ago diagnosing a grey water pump. I checked voltage going to the pump and it was good. So I replaced the motor with a spare. Still didnt work. Turns out the float switch controlling the pump would show proper voltage, but it had so much resistance (bad contacts) that it couldnt run the pump.
43
Macgregor 22 Silverton OR
Check the voltage getting to the pump because the voltage being sent to the pump may not be getting there. Red indicator lights can be turned on for a variety of reasons can you turn it off? Auto ranging meters available today that you can buy for $20 are a wonderful tool to be available but you still need to make sure you're measuring what's working. The frequency of DC current is 1. Be glad other frequencies are much more complicated. It's a sailboat not a car.:waycool:
