Pumpng Away
Robert
To All My 1988 Hunter Legend 35 has a hand pump in the lazarette. Over the past 18 years time has taken its toll. The pump gasket has bad crack. It is a Rule Pump circa 1987 I tried the Rule web page but it appears they are no longer in the hand pump business. Anyody know where I can get a new pump gasket ??? Robert Pensaacola, FL
2,101
I Replaced Mine a Few Years Ago
I'll assume that you are talking about the head hand pump out. I replaced mine (under the head sink on my '88 L37). I found it at the BoatUS Special Orders Desk. Exact pump (Upgraded) with the same footprint. I broke the handle, but the diaphram is still intact. What is the Model number?
Feb 2, 2006
470
Hunter Legend 35 Kingston
No Available Anymore ..
My pump was missing the handle when I got the boat and the rubber diaphram was shot. I looked into getting a replacement for it, but they are no longer available. It turned out that a local chandlery had the exact pump from old stock and a great price. Being a Great Lakes boat, it had long ago been disconnected from the waste tank and I now have the pump set up to be a manual emergency bilge pump.
Jul 1, 1998
3,062
Replaced With Whale Gusher
Consider just replacing it with a better pump. I upgraded mine with a Whale Gusher Titan http://www.whalepumps.com/marine/product_list/7/50/ and it fit bolt-for-bolt ('88 HL-35) so no new holes were required. The flow rate with the Whale is much greater and the handle makes it easier to pump. A few years after I replaced it, wouldn't you know it, Whale came out with a new unit that is designed specifically for sanitary systems http://www.whalepumps.com/marine/product_list/12/68/. It has a plastic housing that covers the neoprene flexible 'membrane'. I don't know what the bolt pattern is but if you don't want any new holes in the bulkhead one could use a backing plate, maybe made of painted plywood? Hope this helps.
Robert
MANY THANKS
Gentlemen, Many thanks. In my HL35 this pump is used for a bilge pump for the lazarette. I did a google search and the going price is about $120.00US for the Gusher pump. Thanks again - Robert Pensacola, FL
