Pump to empty the refrigerator
1
- - Worton Creek
Just bought a 1988 C36 and the pump to empty fridge is not working. How do I get to it? To repair or replace. Does the pump empty overboard or into the bilge? If into the bilge can it be made (easily) to empty overboard?
mortyd
Dec 11, 2004
952
Catalina 30 easy living
pump not working
what do you mean not working? you must open the galley sink seacock first and then the pump should empty overboard then, close the seacock. have you done this?
A
agolden
Pump It!
check under the stove. If there is a wooden storage shelf then remove it and you can reach the pump to replace it. In my 36, I removed the pump and just drain and water from the frig into the bilge.
Tim McCarty
Not sure of the 80's boats, but....
my boat has a sump pump that, switched one way, will pump out the shower stall, and switched the other way, will pump out the fridge. The pump and switch on the 310 are located under the head sink. May not apply to an '88 Cat 36, but it may...
