Pump Out hose
704
Catalina 30 Sidney B.C.
Hi everybody , just installing new holding tank with maserator and new deck pump out. I am wonder ing what is a reasonable maximum distanc to run a pump out hose . If i use present deck fitting it is about 8 ft horizontal and then up 4 ft . Is this ok
Jul 8, 2011
704
Also since I am taking out the old P/O installed holding tank that is under the V bearth that is a piece of crap i am going to install a new fresh water tank in its place strickly for fresh water for the toilet so hopefully no more seawater flushes
Dec 2, 1997
9,011
- - LIttle Rock
No need for a flush water tank...
V-berth is the best location on a sailboat unless that would create a too-long run (more than about 6') from the toilet...so replace the tank if need be, but replace it with a new HOLDING tank. Specify a 1" vent and reroute it to go forward out the hull...that'll insure a good exchange of air that'll keep the tank aerobic, eliminating odor out the vent. I'll be glad to help you spec out the right fittings locations in the tank.
Solving the sea water odor problem is actually easy and inexpensive: Reroute the toilet intake line to tee it into the head sink drain line just ahead of the thru-hull. You can flush with sea water...then, when closing up the boat, after you've closed the seacocks, fill the sink with clean fresh water...flush the toilet. Because the seacock is closed the toilet will pull the water out of the sink, rinsing the sea water out of the WHOLE system before it sit, stagnate and stink. This can eliminate a hole in the boat or free it up to use for washdown or anything else.
You'll find quite a bit of discussion of both of these topics in the Head Mistress forum.
To answer your original question (which may now be moot if you don't move the holding tank)...the last thing you want is a pumpout line that has ANY horizontal run unless the discharge fitting is on the top of the tank with a pickup tube inside the tank...'cuz if the discharge is at the bottom of the tank, the entire horizontal run of the pumpout hose will always stay full of waste, which will result in a permeated (stinking) hose.
Jul 8, 2011
704
Re: No need for a flush water tank...
Hi Peggie ..I finally got back to installing my holding tank after breaking my ankle. I took your advice and bought a new Ronco tank that sits under the port settee which is were Catalina installed one . The tank that is under the V bearth now is an old poly water tank and boy is it bad . As for thepumpout I did order with the tank anew pumpout fitting so i will install it right above the tank for a real short run I am still going to run the maserator line forward to the old toilet discharge which is 1 1/2 in and i will reduce down , this saves me having to put another hole in the hull. I hope it all works
Oct 15, 2009
220
catalina 320 Perry Lake
I have a dedicated fresh water tank for my head. Mine is in an aft Laerette. Works fine and my only advice is to install a one way check valve at the tank outlet and install a shut-off valve with waste nipple somewhere accessible in the line to the head. The shut-off serves 2 purposes; it allows you to work on the toilet without draining the tank (change gaskets/joker valve etc.) and since I have to winterize, the waste nipple lets me empty the tank into the bilge for winter.
Sep 26, 2010
45
Hunter 410 Cheboygan Michigan
You can skip the tank installation by moving the Great Lakes where all intake water is fresh. I'm sure this isn't much help for you but many people under estimate the Great Lakes. I live on it from early June to mid September. 2000 Hunter 410
