The lowest point in the boat is where the drop keel is mounted. Assuming you've found a pumpthat will fit in such a small space. You will have to cut holes in the cabin soles for this installation however. I just use a hand pump.Maybe you could get ahold of a self priming pump. Then you could put the pump under the starboard bunk and run the pic-up to the base of the c/b trunk.
We have a blige pump in the bilge, it' sticks up a little over the wooden cover that's there, but it works fine. As for the water that builds up below the starboard bunk, I just occasionally wet vac it out. Not much water accumulates down there anyway.dlg
