Pump guard filter jams
Kordie
Aug 7, 2011
144
Beneteau 393 Cruising Baja
In my salon head I have a problem
The pump guard filter in the shower pump line gets clogged. Mostly hair. This is good it is doing its job.
But the location behind the head discharge pipe makes it hard to get my hand on it let alone unscrew it.
It also seems to be harder to unscrew than other filters on the boat.
Do you guys have the same problem? Any ideas on making it easier?
Thanks
Simon
Sent from my iPad
Have you considered simply buying a small piece of window screening (plastic is better) and using silicone to daub it down on top? It stops stuff before it gets to your main screen, is easily removable and replaceable.
Kordie
Aug 7, 2011
144
Great idea, thanks
Someone else suggested some sort of drain screen from Home Depot. I am nowhere near one at the moment :-(
