Pulling the AC wiring
Alctel
Dec 13, 2013
264
Hunter 36 Victoria
Due to the PO drilling holes in the top of the roof, near the hatch, I'd noticed water dripping out of the AC plug sockets. I've filled in the holes, but want to pull and check the wire condition.
The wires seem to be inside the actual lining - is there anyway to access them, or will I have to attack a fish wire and pull them that way.
Has anyone else done this?
Jun 21, 2007
2,118
Alctel:
I was on my H36 today and did take a quick look-see in regards to your post.
I really don't think it is possible to view the wires that are routed between the interior lining and the bottom side of deck/cabin top. My first blush is that you should at least remove each of the AC outlets. (I didn't count, but from memory there are three on each of the starboard and port sides. Note their condition. Unscrew the terminal screws on each outlet and observe the wire condition. These locations are where time and moisture will have done its damage. Not so much along the rest of the wire that is protected by the insulation. If the wire ends are corroded or tarnished black then certainly replace all the wire with marine grade tinned type. And the DC wire to the salon lights is also likely suspect. In my case, when I inspected, each receptacle still had shiny metal and the exposed wire that was wrapped around the screw terminals looked still looked metalic. But also, my PO's didn't drill any holes in deck that leaked water!
I think that I mentioned before that you should consider replacing the first receptacle on each of the port and starboard circuits with a GFIC type unit.
regards,
rardi
Alctel
Dec 13, 2013
264
Hunter 36 Victoria
I've already checked the AC sockets and it's pretty rusted up. Looks like pulling it is.
I'm definitely going to put in those GFIC units, any additional safety is always good!
Johnb
Hunter 37-cutter Richmond CA
GFI's are life savers. We had a puppy that twice chewed up power cords and each time was saved when the GFI tripped. The only harm was a ruined cord and a puddle of pee on the floor......
