I have been thinking about upgrading to a PSS seal and started to wonder. How does it actually work? I understand it has a water hose attached to the raw water in that feeds the engine water pump.
So .. if the water pump is drawing water in thru the sea cock then wouldn't the pump also draw water in thru the PSS seal tube also?
If that is the case then isnt it possible to flood your engine if it wont start and you have the sea cock shut by still sucking water thru the PSS seal tube?
Any thoughts???
Any thoughts???
