PSS shaft seal - what do I use for the vent hose?
JamesG161
Feb 14, 2014
7,934
Hunter 430 Waveland, MS
I'm wondering if spongy mounts could cause trouble, especially in reverse
Motor mounts are in general meant to "temporarily" give to various stresses. Rubber's resilience (give and not break) makes it a good absorber of "slight" movements.
I am not sure what "spongy" means but if the mounts return to standard position, your PSS seal compression should too.
I would think "hardened or cracked" mounts would allow a compression shift without return.
Jim...
PS: I would guess a bit more seal flush flow in reverse, but I am sure PSS designed their bellows (seal compression spring) to accommodate both thrusts.
