PSS Shaft Seal for 322
Jeff
Has anyone installed a PSS Shaft Seal on an O'day 322? Was wondering about the size for the shaft diameter and stern tube. Will verify on mine .Just looking for any experiences with this work. Also has anyone had problems with the Petit Trinidad SR bottom paint, flanking off. I had used the Trinidad for years on my 272 without any problems, went to the SR with the new boat and it came off to the barrier coat at the water line. Plan to go back to the regular Trinidad this year. Thanks Jeff
Pete
Put on on mine
I put a PSS seal on my 28 4 years ago. The best upgrade I've done yet. The engine pan is dry and clean, no worry about the packing and no surprises! They have a size to fit your boat but be prepared to remove the old stuffing box. You'll need enough room between the engine coupling and the shaft to slide it out.
