PSA: Check your Fire Extinguishers
Mar 25, 2010
152
Hunter 34 Rose Haven MD
Thanks for posting the recall - think I have one of these. Will check it this weekend when I go over to the boat. Gotta get ready to launch!! :)
Oct 17, 2011
2,809
Ericson 29 Southport..
Not to be snarky, but a short while back I had the extinguisher guy that services the yard here look at mine. While picking his brain, he told me in "the business", they called Kidd 'dollar store extinguishers'.
I replaced mine..
Beneteau 323 Annapolis MD
If your model number, date code, serial number all match up, you get a free replacement in 2 to 4 weeks.
PSA?
Whew.... I thought you were going to recommend a new prostate cancer treatment....and I could not imagine just how a fire extinguisher fits into the picture....:eek::D:naughty:
Nov 18, 2010
2,441
Catalina 310 Hingham, MA
Just to keep with the PSA theme. Annual inspections are not enough. Technically they need to be inspected monthly. Which is simple, is the pin still in place, is the needle in the green and is there any rust or damage to the extinguisher. I also turn mine upside down a couple of times. You should hear the chemicals cascade on the inside. If you just here a thump, or nothing, the extinguisher is no good. Get rid of it and get a new one.
The small marine extinguisher types that most of us have are disposable. Meaning they can't be recertified. They have a printed expiration date. Dispose of them once past the date. Some can be recertified but if you purchased it for under $100 it is doubtful.
FYI, I manage environmental cleanup primarily at gasoline retail stations. The big oil companies are extremely safety conscious. I have to do about 100 hours of safety training annually of which 4 hours are on extinguishers. I have also had to do actual fire response training. If you can find a reasonably priced course near you take it. You would be surprised how useful it actually is on a boat. For instance, those little marine extinguishers have less than 8 seconds of chemical in them. A small fire in a confined area like an engine room could take two canisters to put out, especially if you don't know where to aim and how to use the extinguisher. At the very least, start a small fire on the beach or in a safe place and use one of those old extinguishers to put it out.
Fair winds,
Jesse
Oct 2, 2008
3,813
Pearson/ 530 Strafford, NH
PSA?
The results are the same!
All U Get
Dec 3, 2013
169
HUNTER 29.5 PORT CHARLOTTE FL
Fair winds,
Jesse
DAVIDASAILOR26 posted this:
I was going to reply recommending remembering to shake your extinguishers periodically to unpack the dry powder, but then I found this from the USCG Aux stating that shaking is neither necessary nor recommended. http://coastguardaux.com/f9_11/FireExtinguishers.pdf
... ...if you don't know where to aim and how to use the extinguisher. At the very least, start a small fire on the beach or in a safe place and use one of those old extinguishers to put it out....quote]
My sailing club, Singles on Sailboats (SOS), has a safety day every April. We do have fires on the beach so members can actually put them out with extinguishers donated by members. We also shoot off expired flares, the skippers having exchanged them for new, in-date- ones. This year, Bacon's is working with us for the new flares.
Catalina 320 Dana Point
As a general rule, we used to consider extinguishers with plastic heads as "disposable", while you could service them they just weren't worth it.
You don't want to be in a confined space when you expel one, besides being blinded the powder is an extreme desiccant that will severely impair respiration. Untrained personnel are encouraged to use an extinguisher as an aid to ESCAPE the fire. You want the exit at your back and the extinguisher between you and the fire.
Most fire departments will send an engine company out to train any group that can provide the extinguishers. We used to do it in-conjunction with extinguisher service companies, when a hospital, school, business etc. was getting their equipment serviced we'd train them on the expired stuff.
https://www.youtube.com/watch?v=d6f318W1YEI
