Prop Walk Isn't All Bad
Boats don't back up like cars.Indeed, you can use prop walk to your advantage.Depending on what direction your slip is and how you need to leave your fairway, you can use it to get out of your slip. Our fairway leads to starboard. We reverse out of the slip to port using the port prop walk to our advantage. By pulling the starboard stern to the dock before we engage the engine in reverse, the stern has some room to move to port without hitting the port dock finger, until we have enough movement in reverse to get the rudder to be effective.Also remember, propwalk is most apparent when you aren't moving much. Goosing the engine when in reverse to get way (weigh?) on is absolutely necessary to enable the rudder to have ANY effect.My experience is that most people tend to reverse altogether too slowly, and continually complain about prop walk, when in fact they should be going a little faster to enable to the rudder to take a "bite." It doesn't hurt to use a little more throttle when just starting into reverse, which will offset the prop walk by starting to move the boat backwards faster to be able to get the rudder to be useful.Prop walk can also be used to get you off a side tie, if you're in starboard side to. Use the port prop walk to crab your stern to port.It can also be used to turn your boat in a tighter circle.It just ain't all as bad as it's cracked up to be, horror stories or not.Based on the laws of physics, once ANY prop is turning a certain way, there WILL be some walk, regardless of how much $$$ you spend on it. Sure, some are less than others, but once you learn your boat's behavior, you can use it to your advantage.
